Sure you can. But if you don't connect them in a balanced manner, they become, uh, unbalanced over time.Can I add a second string of batteries to my parallel setup without having to disconnect from the SCC...
This is a far better answer than mine. Safety glasses are a must.I personally would err on the side of safety and
Well ..... Yeah, you could .... but then you are getting into natural selection territory. LOLCan you just squint your eyes? What about if you look away when connecting with just one hand?
Yes but no.Can I add a second string of batteries to my parallel setup without having to disconnect from the SCC...
Thanks in advance
If the batteries are all the same type and voltage and the same age, then sure - I wouldn't be connecting some new batteries I've just bought in with my bank of 3 or 4 year old batteries . . . . especially if we're talking lead acid batteriesCan I add a second string of batteries to my parallel setup . . . .
Interesting... I thought swapping out an older battery for new one (same type etc) was fine.If the batteries are all the same type and voltage and the same age, then sure - I wouldn't be connecting some new batteries I've just bought in with my bank of 3 or 4 year old batteries . . . . especially if we're talking lead acid batteries
Don
Swapping out an older battery for a new one is fine - Paralleling a new one with an older one may lead to problemsInteresting... I thought swapping out an older battery for new one (same type etc) was fine.
