I have been working on a sealed battery box enclosure, with a vent to the outside.
Was going to make the box out of plywood, but the plywood/CDX prices here are currently insane.
Realized I could make the box out of Lexan for just a tiny bit more $$$ than the cost of plywood…..
48vdc fan to ventilate the box is on order.
I have not been able to get the Schneider XW+ Pro inverter’s built-in 12vdc connection to work,
have asked Schneider tech support for advice.
If Schneider can resolve the configuration/HW issue, I will install a 12vdc ventilation fan.
Otherwise, the 48vdc goes in.
One way or another, the gas and heat are going to be pushed out the vent!
The battery vendor suggested a watering system from “Flo-rite”, so I also installed that too.
