mileshanley
- Jun 1, 2021
- 5
I am getting ready to build a portable hand truck 24v solar system that will primarily serve a shed I'm going to build. I will be using a 24v 3000w hybrid inverter charger from Sungold Power, 4-100 w Solar Panels and 2 PowerUrus 12v batteries I plan to wire in series. I've checked the battery specs and this is permissible. My question: I was going to purchase a 24v Case battery to take with me on travels to use in conjunction with a small 24v inverter. I chose 24v because I assumed I could wire the battery in parallel with my system batteries to maintain the 24v with an increase in current. Wires are oversized to accommodate expansion. I have read somewhere that when tying batteries together they should be very similar in specs (typically the same brand?). My case battery obviously will be a different brand. The specs on the case battery I'm thinking of purchasing is 24v 100ah made by NYDPP. Can I wire this in a 2s1p configuration or is that something I can't or should not do? ?Thanks in advance for your help.
