Hi - I've gotten different information about connecting my battery rack with 3 EG4-LL batteries to my eg4 18kpv.
First suggestion - run 1 set of 2/0 cables from the battery rack to inverter. Seems straight forward.
Second suggestion - run 2 sets of 2/0 cables from battery rack to inverter. The reasoning was: to operate at 12kW, the 18k requires 250A from the battery bank. The internal battery breakers in the 18k are sized for 200A so you have to split that circuit in 2 to spread the amps and maximize your output.
I don't understand the 2nd method. If I use both battery connections in my invertor with one rack how do I connect a second rack? Since I only have three batteries what if I added 3 more in the same rack?
Thanks
Thanks
