Julian-Indaiatuba
- Nov 5, 2019
- 45
Hello, sorry in advance if this is a silly question.
i have made a very simple solar set up on which I run a 1000W inverter during the day, and use the full lead acid batteries at night to power 6 led 8W 24V lights for the veranda. These are powered directly by the charge controller’s DC outlet.
When the inverter is turned off at the end of the day, and the batteries are full, the idle voltage for my batteries is about 27,6V
As soon as I turn on the lights, the voltage drops to about 25,8V and after the 12 hours the lights are on, the voltage is about 24,1V in the morning. I thought this low voltage wouldn’t be good for battery life.
I was using two 105Ah batteries in series, but when I saw the low voltage in the morning, I added another two of the same batch.
This didn’t seem to change anything at all. The voltages remained anout the same in the evening and the morning.
I was wondering if this is normal, or if I maybe have made a silly mistake.
Any help would be really appreciated.
I have attached a picture of my batteries. Maybe I have made errors in my setup?
Thank you!
Thank you!
