JunglePower
They were loose alright. VERY loose.So, what did you do to remedy the problem? Was that terminal bolt actually loose? Did you think of actually removing the plastick from between the busbar and the terminal then reassemble it with the teminal actually contacting the busbar? Is it possible? Thanks for sharing the pictures
I followed the original design,simply unscrewed the nuts and bolts, cleaned everything shiny, assembled with an anticorrosive conductor fluid and tightened the nuts as a 50 year journeyman mechanic would. Zero voltage drop.
Voltmeter showed 13.4vdc as soon as a proper connection was made.
But I will insure charging amps never exceed 30adc.
