Gold and silver are better conductors and would make the highest quality bus bars if that is what you mean by “best”.Was wondering what is really best? Plam is ro make them out of copper bar.
Ah, someone with skill and fancy toys, I'm jealous!Plan on putting them in the mill and decking them so there flat.
If you want to do the math (or maybe someone else here has some spare brain cycles?) you can calculate the cross section area and compare that to AWG cross sections. With the correct AWG equivalent you can determine the maximum amperage that can be run thru your copper bars.Was thinking 5/8"×3/16"
3.382 is more than 99% SOC.Yes I will make small slots in them. Copper pipe is thinner then 1/8" I would say when smashed.
First I used one wire. Noticed the voltage was dropping off away from it. So I added another at the other end. That brought it up from 25 amps to 37.5 amps. Today I went and bought more wire and added a 3rd. Holding at 41.8 amps.
I started this at 3:30 pm on Saturday at 3.293 volts. I'm now at 3.382 volts.
Ya lost me. From your picture, it looks like you are doing a parallel charge of some sort. The two wires on the right, on the same end of the battery are a problem. You should have + lead on one end of the group and - lead on the other. Adding the midpoint wires will help somewhat.First I used one wire. Noticed the voltage was dropping off away from it. So I added another at the other end. That brought it up from 25 amps to 37.5 amps. Today I went and bought more wire and added a 3rd. Holding at 41.8 amps.
The thickness is only half of the equation. Mine are over an inch wide when "delicately hammer machined".Copper pipe is thinner then 1/8" I would say when smashed.
I'm top balancingYa lost me. From your picture, it looks like you are doing a parallel charge of some sort. The two wires on the right, on the same end of the battery are a problem. You should have + lead on one end of the group and - lead on the other. Adding the midpoint wires will help somewhat.
What are you trying to do?
Thats a good thing to do.I'm top balancing
Mine were "delicately machined in the shop press"The thickness is only half of the equation. Mine are over an inch wide when "delicately hammer machined".
Just one more step before you have the elegant hammered finish... :*)Mine were "delicately machined in the shop press"
I suspect that all your wires are applying a fairly distributed and balanced charge.I took off all the wires and left just one. Put + on one end and - on other. Amps dropped to 24.5.
So I put back on all my wires this way and now back to 41.8 amps
I think wrong and will hurt it?
Well with in reason. I have 8 280 eve cells. Making a 2p4s pack. Plan is configure like this. Will make the sides all one piece. Plan on putting them in the mill and decking them so there flat.
Thanks
Just out of curiosity, what is it about those that you like? Is it the box areas or the battery shape/form?For 2P4S I like these layouts better:
Stick a fork in it, its done.3.64 volts with no load.
