Best parameters for charging Lithium battery
RobbieD
Hi fellow solar enthusiasts,
I have an Epever MPPT 20AMP solar charger. It allows my to custom set certain parameters. The items I can set / change are in the attachments. What would be best to get full 100 % capacity of the battery? It’s a 12v 100AH if that changes things. 1st picture is of the battery itself obtained via a Bluetooth connection to the battery.
Cheers Robert
1st you have to know what kind of battery you have. Make Model and chemistry if you know.
After that, a proper answer can be worked on.
One thing for sure, you never equalize a Lithium battery, that is only for lead-acid batteries. Don't confuse balance with equalize, it does not mean the same thing.
Thanks Jason,
Brand is deep cycle systems, in Australia.
