I’m going to chime in with our current idea of what is getting installed in our 23’ DIY camper(full time starts next year!). For starters, it’s cheaper and more energy dense to build a battery bank. 48v seems to be the meta. Maybe 24v if our layout doesn’t permit a massive, single battery bank. But 12v isn’t going to be space efficient.
Next, roof Solar isn’t efficient unless you can actively change the panels angle towards the sun. So DIY suit case style 200w (2x 100w) panels appears to be our best option with 600-1000w on roof. So almost 2kw of Solar total if not more.
Then a big hell no to AIO units. The idle consumptions alone is a deal breaker. So probably sticking with using victron components individually to keep idle down and keep up efficiency.
A big power consumer is A/C. 12v or 24v rooftops are a no go for us. Initial cost is already too high compared to an inverter mini split. Plus the mini splits use like 2-300w to maintain temps vs a rooftop using about twice that constantly.
Propane for cooking and water heating. A small diesel tank for a diesel heater for any cooler periods of time.
We’re also installing a small propane/gas generator as a back up. Even if we rarely use it, it’s a nice safety net.
Just our current plans! So hope that helps
