I'm still in the "Where should I put my panels" mode (compliments of living on a farm I have both space and no regulations). Vertical looks interesting since it would eliminate snow load (and benefit from snow on the ground) and that is going to be the scenario where I would get the least power of the year. With panels being one of the least cost items in the system, I've no problem with just adding more.
So the question becomes: Just how "vastly" is vastly? Again, focus is on cloudy, snow covered, days since those are the ones I'm most likely going to lose grid power on.
Ah, finished the video. The image of using solar panels as fencing is intriguing - But how the hell are those things wired? I have miles of barb wiring fencing on the farm, but the wiring cost of running 48V wiring for standard inverters is staggering. My guess is they are running those at a much high voltage and using non-household inverters and charge controllers. Finally, as displayed, field grass is going to seriously shade those panels and I doubt they are designed to handle being hit with weed wackers for clearing (especially the blade types we actually use on farms, not the relatively wimpy plastic wire types). FYI - if you don't clean the grass at least yearly, soon there will be brush and trees growing on those runs.
