Hi, I already have a Victron MPPT 75/15A solar charger controller. And I am trying to build my own powerwall with LifePo4 32700 battery cells.
Because I like a lot the DIY philosopy, I will try to make also the famous DIYBMS v4 or similar. but it is the same, and it is not key to this question.
This post is because I have a doubt about configurations.
I will have to configure the MPPT solar charger controller and the DIYBMS to work togheter
My plan is 8 LIFePO4 in series, so I will have 3,2 x 8 = 25.6 V nominal, and maximum: 3,65 x 8 = 29.2 V (it is not object here to discuss whether it should be 3.55, 3.6 or 3.65 or 3.7, consider it as an example)
DIYBMS (an others) does balance in the "up voltage", I mean, it tries to get all batteries with 3.65 V, no more.
But we also have the MPPT configuration about maximum voltage of battery.
So the question is: what is better for the "29.2 v and 3.65v" example?
1. MPPT: max 29.2 and BMS: max per cell 3,65 - gap. And what gap: 0.1V or more or less?
2. MPPT: max 29.2 - gap and BMS: max per cell 3,65. And what gap: 0.1V or 0.2V or more or less?
3. MPPT: max 29.2 + gap and BMS: max per cell 3,65. And what gap: 0.1V or 0.2V or more or less?
with option 1, theorically, MPPT will NEVER stop charging when all 8 cells are well balanced at 3.65 - gap, as they doesnt reach 29.2 V
with option 2, theorically, MPPT will stop charging before getting all cells at 3.65, because of the gap
with option 3, theorically, MPPT will NEVER stop charging, all cells will be at 3.65 and the DIYBMS must to stop the charge of each of the 8 cells.
(option 1 and 3 are very similar in their final result, MPPT will not stop, and BMS will have to stop the charge of all the cellsl)
What is the better option? What about the gaps? and what about the accuracy between voltage measurements of MPPT and BMS?
Does anybody has a similar instalation? Do you think that is better to post in other forum?
Thanks a lot and happy new year.
