mikefitz
Solar Wizard
- May 28, 2020
- 2,979
As suggested if you battery charger is programmable set the charge voltage, ( termed absotbtion or boost) to around 14.0 volts. This will charge your battery to a useful 'fullness' perhaps 99% of the absolute capacity of the battery. There is no need to completely charge to absolute maximum capacity as this would reduce service life.So do I stop charging when the battery reaches a non-nominal 14V or is 14V the nominal voltage that it's supposed to settle to sometime after being fully charged?
Once charged with no load the voltage will settle to around 13.4 volts.
If your charger has a float setting set this to 13.4 to 13.5 volts, should not be higher than the resting voltage.
If possible do not leave the battery for long periods at maximum state of charge.
Depending on the chargers used with your battery the settings in the Victron shunt may need changing to get correct sync to 100% SOC.
Mike
