Looks balanced enough at those voltages. If you get a large disparity around the top of your charge range a top balance may help. Or you can be conservative on how high you charge them (what i do) and have cells balance in your working range.
I am the BMS for my cells so I have conservative charge and discharge settings and usage. So far so good without a BMS with about 500 charge cycles on my batteries (5 batteries ranging from 22ah 4s to 412ah 2p4s).
Again, its hard to help debug a BMS when all one has to go by is that it does not work. Maybe its wired wrong? Maybe it really is bad?
