Hello
Do BMS wires all need to be the same length? I have built four 48 volt batteries to date and always made all wires the same length. The process is time consuming and you end up with lots of extra wire to hide. I have done the same thing with my separate active balancers, again time consuming and lots of extra wire. In all cases I had used Overkill 100 amp BMS and a separate 5 amp active balancer.
I am about to build some new batteries, this time I will be using the JK invertor BMS 150 amp with 2 amp active balancer built in. I would really like to make all wires just long enough to meet up with their prospective batteries and avoid adding a lot on extra wire. Can I do this?
My understanding of the battery positive and negative run to the busbar and charge controller should be the same length for all batteries. Is this still correct?
Ldc
Ldc
