Hi all,
I was wondering if BMS's in general limit their continuous output load current or if they just cut off the load on a current threshold? If the latter, are there BMS's available where you can adjust the maximum continuous ouput load current?
I'm putting up a 3,5kW solar array which will be used to charge a 14kWH LiFePo4 battery bank at 51,2V nominal, so 280AH per cell. I'm also wondering about the cell balancing capabilities of BMS's.
I hear good and bad things about JBD, are they worth getting and any good at these two functions? Are there better recommendations?
Thanks to anyone willing to spend the time and effort on trying to help!
