Motormouth
Is the MPP PIP 2724 LV-MR bonded or floating?
I guess I should ask this for two situations,
1) if it grid connected does it use the main panel bond from the grid ground or is it self bonded?
2) if it is stand alone is it self bonded or floating?
I want to avoid ground loops.
Trying to decide whether or not to pass the output ground through a transfer switch
If it is floating I will pass the ground through the transfer switch to the main panel bond, which would be my preference.
Is if it is self bonded is there a way to make it floating?
