lisalizajohn
- Sep 4, 2020
- 22
I have finally started working on a long postponed project: building a small, lightweight enclosed trailer to be able to camp in Florida with a fridge and an AC. While I expect to spend most of my time in locations with access to at least an extension cord, I'd like a battery system to get me through the semi-frequent power outages I experience in campgrounds, as well as be at least theoretically capable of boondocking. Ideally I'd be able to use my Chevy Bolt as an additional power source while boondocking, but I'm open to using a gas generator.
I have an inverter/no-surge portable air conditioning unit (ASIN B09L15X5MD ) that maxes out below 1500w, and easily cools a large poorly sealed section of my workshop at less than 400w. I have a small refrigerator (ASIN B01DZQICZK ) incoming that is rated for .8A@110v, with an estimated 26w average - I won't know until I test it how accurate that is or demanding the surge will be. I also have an induction burner (ASIN B08YJ6ZPFJ ) with 600/900/1300 watt settings - I have not tested it but reviews indicate that it does properly limit the power consumption. I am comfortable with turning off the air conditioner and/or fridge to use the induction burner, but I am hopeful that will not actually be necessary.
The initial plan in my head is to purchase eight 280ah EVE cells and a 2200w Samlex (EVO-2224) inverter/charger. I should be able to limit the current of the AC input to be able to use the Bolt's output (albeit through another inverter, so some hefty additive losses there) or an extension cord from a friend's back porch. My area for solar panels is pretty limited - I would likely not even bother with solar initially, though I can theoretically mount up to ~750w of flexible solar panels.
Am I on the right track? Is there a better way to accomplish my goal? Your experience and knowledge are very much appreciated.
