This is why The lugs ABSOLUTELY POSITIVELY must be in direct contact to the wire terminals. No washers under them.What about the resistance of the stainless steel?
FYI -The Battleborn batteries "come standard with a flag style terminal post with a 3/8” hole to accommodate a 5/16” bolt and lug sizes up to 2 AWT. Larger lugs may require a 1/4" bolt. All batteries ship with 18-8 stainless steel 5/16 – 18 bolts, BRASS washers, and 18-8 stainless steel nuts with nylon inserts. If multiple lugs are used, the washers may be removed, or longer bolts may be required in order for the bolt to fully seat into the nylon insert of the nut". I think the terminals are solid brass. Am I wrong?Best conductor is silver. Copper seconds, followed by aluminium.
Your lugs are also plated, usually with tin. If you are worried about galvanic corrosion, use an antioxidant compound.
The correct solution to not stripping the threads is not overtighten the screws.
As said earlier, all professionals, all manufacturers and all hobbyists use stainless fasteners. They are the best tool for the job.
battleborn Terminals are solid brass.FYI -The Battleborn batteries "come standard with a flag style terminal post with a 3/8” hole to accommodate a 5/16” bolt and lug sizes up to 2 AWT. Larger lugs may require a 1/4" bolt. All batteries ship with 18-8 stainless steel 5/16 – 18 bolts, BRASS washers, and 18-8 stainless steel nuts with nylon inserts. If multiple lugs are used, the washers may be removed, or longer bolts may be required in order for the bolt to fully seat into the nylon insert of the nut". I think the terminals are solid brass. Am I wrong?
the terminals are brass (you said the terminals are usually tin coated)EDITEDThey send stainless hardware. What is your point?
Yeah, I saw that too and asked about it. Was told by JH to use the same size bolt as the hole. I'm all good now. Thanks.battleborn Terminals are solid brass.
I don’t know why “larger lugs may require 1/4” bolt” some lugs might only have a 1/4” hole in them... don’t use those lugs.
I would use the bolt that fits the battery terminal hole, and get lugs with that size hole as well. If stacking lugs, longer bolts will be needed.
He was swapping terms. He meant many wire lead terminals are tin plated.the terminals are brass (you said the terminals are tin coated)
I wouldn't call this a flame war, and I hope it doesnt become one.I spoke with Battle Born about threading the terminals for extensions to get the terminal out to the sides of the batteries, and they use a version of low Electrical Resistance brass (opposed to structural/tool brass).
For those that don't believe the bolt can or would conduct electrical current, I would point to the heavy duty breakers, switches, lugs on high amp contactors, etc.
The bolt can very well pick up amperage on the 'Off' side of the BB terminal, and conduct it directly to the 'Off'' side of your cable terminal, adding to the total amperage load being moved.
Electrical current doesn't 'Magically' stop at the terminal to terminal interface...
For the same reason you use heavy lugs and over gauge wire, you *CAN* use a brass, or even copper bolt it DECREASE Resistance & INCREASE Conduction at the connection joint.
Air gap, tapers, radius edges, small bolts in big holes are ALL missed opportunity to increase Conduction.
Since most ELECTRICAL conductors tighten to INCH POUND specifications, a heavy duty structural fastener isn't necessary, you simply don't need a Grade 8 bolt for an electrical connection,
Which by the way when overly tightened against brass/copper will deform the brass/copper, denting it, and you LOOSE conduction surface you can make contact with...
As for dissimilar metals...
Copper is copper, electrical brass is about 75-80% copper, bronze is 90% copper.
Even cartridge brass (most common) is 70% copper.
*IF* YOU (personally) want to stick a steel bolt/nut/washer in there, it's your system, do what you want.
Just don't try to sell carbon steel or nickel steel ('Stainless') as as a proper electrical conductor to anyone else...
Silver is the best (common) conductor of electrical current.
Copper is the second best (common) conductor of electrical current.
Brass or bronze beat aluminum with high amp DC.
With copper, bronze & brass bolts/nuts/lock nuts available, and only using two per battery,
I don't see the reason for a flame war if someone wants to use them like high amp industrial applications REQUIRE.
The more you spread the ELECTRICAL CURRENT out over HIGHLY CONDUCTIVE MATERIAL the less any one part of the joint has to deal with.
You use big cables, and if you are smart, big terminals with lots of contact surface area, but using the bolt to conduct even more and spread that current out even further is INSURANCE when age, tarnish/corrosion, etc set in, and they WILL set in, it's just a matter of time & environmental conditions...
What is 'Easy' is rarely 'Correct', Like Crimping (mechanical connection) and not using a proper silver bearing electrical solder (100% electrical connection)...
We are talking in excess of 100 Amps here, all that YOU paid top dollar for the panels to produce, the batteries to store, and the copper to move around.
And then cheap out on 5 cents worth of solder and $2 worth of brass or copper bolts...
All that expensive copper, panels, batteries, EVERY WATT COUNTS, and electrical resistance burns watts, restricts amperage movement, ect.
Considering the proper solder seals the copper against moisture while maintaining a solid electrical connection, and brass bolts keep electrical resistance out of 100 or 200 Amp circuit, what do you think that $2.05 worth of solder/bolt is worth when your harness doesn't have to be taken down for 10 YEARS (warranty life of Battle Born batteries) of constant use without fails?
The only point in your post I disagree with is the "over 100 amps" part.
Battleborn limits their max output to 100 amps.
But on a battleborn battery, limited to 100 amps, is the fastener going to be part of the circuit?
I am ABSOLUTELY CERTAIN the resistance of the steel has a millivolt inductive affect. I just wouldn't choose a fastener material that would be susceptible to vibration issues like copper or brass in a mobile situation.
