Calendar aging... me, not my LiFePO4'sWhaahapppened?
EDIT: @hardtop i missed a key word, not needed to be exact:I also want battery heaters and I haven't found quality heaters that are the size of my cells.
I choose the DIY route, but I haven't finished the build and my batteries have been collecting dust for 2 months lol. I bought 4 EVE LF304 Grade A Cells from 18650 battery store and they told me I don't need to top balance. But once they arrived and I posted about it here everyone says I need to top balance them. Tbh, that was pretty disappointing and I don't want to be buying a DC power supply just for this.
I also need to harness the batteries so they stay together and don't swell. I drafted a design and sent it to a plastic shop. They said they would build it but its been 2 months and they haven't given me a quote yet. I want stainless threaded rod to compress them and nobody carries that around here so I'll need to go online for that. The other tools I'll need to buy to terminate the wire connectors, but I don't have an issue with that because I'll be re-using them. I also want battery heaters and I haven't found quality heaters that are the size of my cells.
The biggest advantage that I'm holding on to is the ability to grow the battery pack by adding more cells and more BMSes.
I think the cells I bought are quality and I'm wondering what is the impact if they aren't top balanced? I don't understand the concequences of skipping that step and why the 18650 tech support would say I don't need to but people here say I do. My cells are very close in voltage together, I just measured them 3.307v, 3.308v, 3.308v, 3.307. That is a one one-hundred thousandths of a volt difference. Pretty good if you ask me, but I should be the guy buying an already setup pack lol.
Excellent points @Steve_S! Having the right tools and skills are very important when creating a solution that can kill you or burn down your home if not done properly.I build batteries and have been doing so for a while and I feel I better Chime In here.
- It is not that hard to do but it is not a simple slap-it-together deal, unless you want troubles.
There are tools required ! That costs money and a few things that can't be skimped on either such as a good quality Digital Multimeter (at least 2 decimal point accurate) with DC Clamp. Wire cutters, crimpers (Lugs & Terminals) and more... Of course a DC Charging Powersource to top balance etc... This stuff adds up FAST... some of us have the gear because we are into electronics etc but there is always something we don't have.
The Question, if you have the tools & equipment, then DIY is a great option, but if you do not have the tools etc, will that "investment" have more life beyond building the batteries or not ? That can only be answered by YOU !
Cells, Cases, BMS' etc are all easily obtained and there are Known Good Vendors that have been supplying the membership here for quite some time. You can build Larger Capacity batteries than those on offer by most vendors.
! Take 48V Rackmounts, they are mostly 100AH, a few get to 200AH but not beyond that.
A 48V/100AH Pack weighs 47kg (103.6lb) +/- Where a 48V/280AH weighs 135Kg (297lb) +/- a bit. and can't be mounted into a rack for obvious reasons.
Only thing I can telll you on that front is that my cells have been good for little more than 2 years.I am honestly leaning towards building my own battery, but I don't know how reliable those 3.2V cells are.
Greay info, exactly what I was looking for!We purchased a DC power supply to top-balance our first build. Quickly transitioned to installing Heltec 5a active balancers (with an off/on switch) for subsequent builds. The Heltecs do a fine job of top-balancing. Only takes a few hours with large deltas---smaller deltas, less than an hour. Plus they can be easily switched on to top-balance, as needed, down the road. Rewiring a battery pack, after the fact, to top-balance with a DC power supply is a PITA. The DC power supply has come in very handy for various other electrical projects and testing, but we no longer use it for top-balancing.
Once you start doing DIY builds you'll find the very least of your worries is reliability. Cell failures are extremely rare. BMS's may occasionally fail, but they're very easy to replace. Your biggest concern, by far, is hoping the vendor sells you a well-balanced set of cells. Top-balancing can't fix cells that have inherently different ah capabilities. This is why purchasing from a reputable source is important
Correct. The Heltec 5a 4s balancer's 5 wires (4 positive cell wires plus neg) will simply parallel with the 4s BMS's 5 sensor wires (also 4 positive cell wires plus neg). Each positive cell wire (from BMS and Heltec) is cell specific (3.2v/6.4v/9.6v/12.8v)---they must be connected in the proper order. Not sure about the Heltec, but you can potentially damage a BMS if you connect these wires in the incorrect order. We crimp the BMS and Heltec wires into one wire terminal to cut down on clutter.Unfortunately I haven't read a much about Heltec active balancers so I'm unclear how they'd be used to intially balance the cells. Are you suggesting that I connect the cells together, then wire up the BMS and also wire the Heltec cell balancer to each cell. Then also install a on/off switch to the Heltec so I can turn it off and on periodically?
Andy does a video on the Heltec. It's for a 16 cell battery, but I have the same one for a 12 volt battery. I installed mine with an on/off switch.Great info! I've heard about
Unfortunately I haven't read a much about Heltec active balancers so I'm unclear how they'd be used to intially balance the cells. Are you suggesting that I connect the cells together, then wire up the BMS and also wire the Heltec cell balancer to each cell. Then also install a on/off switch to the Heltec so I can turn it off and on periodically? I'd love to see a wiring diagram. Is there a good post or posts to read on this topic? I did a search and got SO MANY hits, that I information over load!
You folks have convinced me to go the DIY route, I was worried about getting quality cells. If I put it together and set it up my self, I'll be better able to properly maintain it in the future.
Hello @dareggaemon . Could you please share what parts and where did you buy? I'm interested in buying parts for the new system and would be great to get some parts list and a reliable supplier.I've been doing DIY solar for the last two years. I just expanded my 24kw system to 52kw and the additional 28kw cost me $3,307 including tax.
The Lifepo4 cells I bought are now cheaper on AliExpress. It took 2 and half months for the batteries and parts to ship from China. I did not buy the cheapest ones. I watched a lot of youtube reviews from people who bought lifepo4 cells and read a lot of reviews and forum posts. In the end I went with a the cheapest supplier I found with creditability. No way could I buy a premade 28kw battery bank for $3,307. This cost includes, the batteries, wiring, JK BMS, fuses, accessories like the 4.3 display for the battery, and tools that made my life easier when building the battery.
I wanted it hidden and out of the way so I built it in a corner in my garage. I wanted to also be able to store things on top of it. but I ended up installing the screen on top so I can check the status without having to check the bms or inverter app. The enclosure is bigger than it needs to be because I wanted a lot of space for maintenance if needed.
I really want to put everything in a power shed but not ready to spend that money yet.
I agree, which is why I bought from and recommended a seller from Will Prowse battery recommendation page. Better to buy from a trusted store then to give your money away to scammers.Be careful with buying cells from Aliexpress. Many of the listings there are plain scams, and a lot of other sellers are less than honest to say it mildly. Aliexpress is good for many things, but battery cells aren't one of them.
I'm just learning and would very much appreciate anyone who can help me understand the above statement better! Thanks, here is a direct question concerning this issue.Most common user issue with self-contained LFP batteries is allowing cells to become unbalanced due to lack of sufficient absorb charge time to allow BMS to balance cells.
If you are doing absorb to 28.0-28.4v for several hours every day, then you are keeping up with balancing.I'm just learning and would very much appreciate anyone who can help me understand the above statement better! Thanks, here is a direct question concerning this issue.
1.) As long as my batteries are reaching "Absorb Voltage Parameters" several hours a day while under load, does it make any difference if my CC stays in BULK mode all day and never cycles into the ABSORB setting?
If so please explain why. Thanks in advance for your valuable time...
1.5 kw SA
Out Back FM 80 CC
3 x 100 ah 24v Li Time
4000 w Inverter
Thanks a Lot! This is my situation I want to correct..If you are doing absorb to 28.0-28.4v for several hours every day, then you are keeping up with balancing.
Probably biggest mistake is reducing absorb voltage to 27.0 to 27.2v under the misguided impression that lower absorb voltage will help LFP battery last longer.
BMS's do not balance bleed a cell until it reaches 3.4v. Many 12v self-contained LFP battery BMS's only balance dumps 50-100 mA of bleed current. Roughly when misbalance between cells approaches 0.5% to 1% capacity difference, depending on charge current rate, there will likely be charge shutdown issue due to a cell going overvoltage when a full charge is attempted.
1% of 100AH battery is 1AH / 0.050 mA BMS bleed takes 20 hours of balancing to equalize. You want to avoid getting into that condition by keeping up with balancing on a continuous basis.
A self-contained 12v LPF battery with no Bluetooth monitoring of individual cells is flying blind making it more likely to evolve into an unbalanced condition that takes a lot of absorb time to correct.
Thanks NOW we are getting to the crux of my misunderstanding as to how often must batteries be brought up to Absorb to maintain proper balance.If charging to lower absorb voltage, eventually the misbalance will get to the point where one of the cells reaches 3.4v and will start to bleed. But this is slow and will not fully balance battery.
Best way to ensure full balancing is to have a battery absorb voltage of 3.5v times number of series cells. 3.5v x 8 = 28.0v.
If you do at least two to four hours once or twice a week you should keep up with balancing. As battery ages, or you run higher discharge currents on battery, more balancing time may be required.
Keep in mind a new self-contained 12v LFP battery, as received by you, may be somewhat out of balance due to sitting in a hot container on a ship or on warehouse shelf for several months with variable individual cell self-discharge rate. You should do a full charge / absorb time to balance battery when you first receive it.
Question on Non Bluetooth LFP batteries? Can I just add a Shunt to help me keep an eye on individual cells? If the BMS is working properly, shouldn't it keep me with in safe parameters for longevity? Thanks for your valuable inputIf you are doing absorb to 28.0-28.4v for several hours every day, then you are keeping up with balancing.
1% of 100AH battery is 1AH / 0.050 A BMS bleed takes 20 hours of balancing to equalize. You want to avoid getting into that condition by keeping up with balancing on a continuous basis.
By the time you notice battery capacity reduction due to lowest SoC cell, you are likely several % of rated capacity misbalanced between cells and may take a week or more of absorb level voltage to rebalance battery.
My 320ah 3.2v 16s LiFePo4 batteries from Aliexpress came very well packaged and had no issues; $1,200 total; bought the case with BMS separately. Batteries do take a long time to get here; month and a half.Be careful with buying cells from Aliexpress. Many of the listings there are plain scams, and a lot of other sellers are less than honest to say it mildly. Aliexpress is good for many things, but battery cells aren't one of them.
