Build a LiFePO4 battery or buy one already made?
My 320ah 3.2v 16s LiFePo4 batteries from Aliexpress came very well packaged and had no issues; $1,200 total; bought the case with BMS separately. Batteries do take a long time to get here; month and a half.
For every positive experience, we've seen a dozen negative ones. I'm just hoping that those new to the game have a good experience, and Aliexpress tends to be more risky.
Quite a few posts discussing ways to achieve a balance between a "normal" charge profile vs. a charge profile that allows the BMS an opportunity to provide good cell balancing using the very low 50-100ma of balancing/bleed current typically found on most BMS's. Most solutions involve a dance between these two charge profiles, not to mention the extra baby-sitting time.
Unless I was dealing with a sealed, off-the-shelf battery/pack with an active warranty, I think I'd much prefer to install an active balancer. If we need to balance, we turn-on the active balancer for an hour or two (with the cells above 3.4v). Once the delta is below our preferred threshold we turn the active balancer off. We then use our normal/regular/preferred charge profile until such time as the cell deltas get too high again---maybe a few weeks, a month or so later, who knows. At that point, rinse and repeat.
We purchased the same cells from 18650. The voltage was *exactly* the same on all 4 cells (3.302v). Even so, we still needed to top-balance due to excessive deltas (imbalances) when charging above 3.500v.
You could always pass on the top-balance and charge your cells normally with the BMS installed to see how they do. You may get lucky and experience minimal deltas as charge voltages rise from 3.500 - 3.650v. If you don't get lucky (likely), you'll soon discover a high delta negatively impacts (reduces) the overall ah output of the pack. Probably hard to visualize all this at this point, but suffice to say---large deltas (or a "runner" or two) suck. If this continues to occur after a top-balance, odds are you'll be discussing cell "quality" with 18650.
If you decide to top-balance and you don't want to purchase a DC power supply, you do have the option of using a $25-$30 Heltec 4s 5a active balancer (may want to install an on/off switch for a permanent install). The Heltec will top-balance your cells in an hour or two. If you need to perform another top-balance down the road, simply turn on (or use) the Heltec again.
Always lots of debate about compression. We passed on compression due to important space constraints. If our maximum cycle count drops from 4000 to 2000 because we didn't compress we're fine with that.
As for heating the cells/battery, we found a set of 4, 80x100mm 24w silicone heating pads will heat 200-315ah 4s packs well. Wired them series/parallel for 24w of *total* heat (wired all parallel = too much heat). Applied them to the sides of the cells between layers of heavy-duty aluminum HVAC tape. They keep the cells in a 200-315ah 4s pack above 45-50f even with ambient temps as low as 0-5f (inside a Group 24 or 31 battery box with top and no insulation).
So far the cells have balanced out just fine. Cell volt diff is about .02 during the final few minutes of charging at 3.5V. There are 56+ cycles with 17k cycle capacity on the battery and I've been using it daily for months. I did have one cell that was .2V low at end of charge after several months of use, but I found the bus bar bolt came loose. I tightened it back up and after a few charge/discharge cycles it went back to normal. Maybe I will need to top balance later, but right now I see no evidence that I need to.
So folks just to keep this topic alive, I will post status and results for what I have just ordered (yes actual order in so $ is actual)
Between the Will's videos and also Nate's DYI Solar, this seems to be the way to go to support a full house system.
32 3.2v 280ah LiFePo cells (rated for 300 actual ah so effectively 600ah)
2 DIY battery boxes with JK 200amp BMS w/ touch screen, PCB, circuit breaker, etc
$3,024 all in cst with shipping
$3k/30kw = $100/kw
Closest example of pre-built rack mount that I can find is $900-1,000 for a 100ah battery or $180-200/kw
At this point in time DIY is 50% of premade batteries.
If someone can provide something that shows different, I would really like to see.
I will post sources and status of the build once I can start some testing.
$3k/30kw = $100/kw
Where did you get it from? Also keep in mind many of the circuit breakers included in these DIY kits are not safe when you start adding batteries in parallel. They simply do not have high enough interrupt current rating.
Allibaba but based on a lot of feedback and review on which store/mfg to buy from.
Agree the CBs are more of an easy on/off switch…. Each bank will have a + terminal fuse.
There's a couple vendors in the US that are selling cells that are just a hair over the price of cells on aliexpress/alibaba. If you're weary about quality or don't want to wait for long lead times, that might be a good route to get you started.
And it depends on how much power you are going for. I need 90kwh, and the cheapest prebuilt with any sense of quality is 1k/5kwh, or $18k without shipping. Buying sells individually, I can build 15kwh for $1200 with bms and compression case included, and that's $7200 shipped.
The more you need, the faster the gap grows, which means it makes a lot more sense to diy pack with higher capacity.
Do you have list of those US sellers? 18650batterystore.com in the US has been called out for selling cells with terminals that are not properly welded on so they are popping off.
Then 18650batterystore should be liable for the products they sell. Not saying they will do the right thing, but here's hoping.
I have gotten 4 packs off batteryhookup.com so far no issues, they've been flexible, and they're local. But their prices shipped don't seem unreasonable.
I completely agree. Anyone who wants to have battery power for more than one day without the grid is going to need a huge battery bank of 50K or more. That's four EG4-wallmount indoor batteries, which is $13,196 before tax and shipping. You could build this yourself for $7k tax and shipping included. And, you could build it for a lot less if you build your own enclosure.
Keep in mind that generally the grid goes down during storms when you don't have sunlight to easily recharge your battery bank. And, if you have an electric car you will need a larger battery bank.
there was nothing wrong with the ones I got from them.
There's a limited number of US based lifepo4 cell vendors. They *all* have issues of one kind or another. Pick your poison. If you're not comfortable picking one, you may want to consider going with an off-the-shelf unit (with a warranty that's hopefully worth the paper it was written on) as a plan B.
For what it's worth, we've purchased a number of cells from 18650. Granted, they don't have the most timely, responsive communication, but all said and done they stepped up to the plate when we needed them to.
I like my batteries in a metal enclosure. The enclosure with a securely bolted down BMS with nice from or side panel with communication ports. And the older I get the more I like things on wheels.
Figure out what enclosure you are going to use and that seems to be the hardest starting point for me. Add up all the parts and if it is over the price of a commercially produced battery with free shipping that that answers it for me.
Are there any commercially produced batteries cheaper than DIY box builds? I don't think I've found any but I'm interested. I'm in the market for two 15kwh 48v batteries with coms. I'm usually finding the DIY boxes to be at least $1000 cheaper than buying commercial batteries.
I found I wanted an outdoor battery so I went with the Midnite powerflo16 battery. It has a built in 2” hole for conduit so I don’t need to get an external conduit box which makes the install cleaner.
Less than $169/KWh with free shipping and for a 280Ah 14.2 KW battery is pretty nice deal for me. I have plenty of other DIY areas to work on so I have to be practical with my time.
with 2A active balancing, nice
Also is heated but doesn’t matter in CA weather. The other secret is sign up at current connected and you will see a very nice price compared to eg4 power pro, etc. I’m waiting for another free shipping promotion before I get a second one.
