iClick
I'd like to install a Class T fuse into my yet to be built 12v 310A power station. The reason for the choosing a Class T fuse is to protect against a catastrophic direct short where there could be in excess of 10k Amps (happy to be corrected here)
Now given that Class T fuses aren't cheap ($80 AUD) would it be feasible to install a higher rated Class T fuse than is needed by my cables and then properly rated ANL or MRBF fuses that I would hope would blow before the 'last resort' Class T fuse.
In my case, I have 64mm SQ 00B&S cable connecting a 2000W inverter to a 310Ah battery.
Would it be akin to wearing two condoms If I used a 250A ANL fuses to protect the cable and then have a 350A Class T fuse between the battery cut off switch acting as the direct short fail safe?
