I have a DIY battery with daly BMS, there is no connection between Inverter and BMS, Growatt inverter is setup as Lead Acid, so i only look to the voltage.
100% soc is about 56.7Volt
This is my DIY battery with LTO cells works fine (more than half a year operational.
https://sites.google.com/view/spikeautomation/diy-battery/diy-home-battery-project
can i connect one from ali express over it Ali express battery in parrallel . With no connection to the BMS ?
