Larry12
Can I run 12 volt 120 feet? I want to power a 12 volt Shurflo 2088 model RV style pump to pump water from a tank uphill to my house. I have been using a 110 volt Shurflo 2088 but want to go solar. My battery is 150ah and is powering one 12 volt model 2088 Shurflo120 feet away from the location of the tank where I want to put the new 12 volt pump. If this can be done should I use #12 automotive wire in conduit (I was thinking I should based on a conversation with an electrician).
