I learned Bluetti did/or will release a cable so you can use the B300 batteries on the new AC500, I'm curious if anyone has heard if they'll make one to use the B300S batteries w/the AC300.
From personal experience: The AC300 will run with a B300S battery. I do not know that the battery will self-heat, but it seems like it should since that is an internal function of the battery. Buy the battery cable that allows the AC500 to connect to the B300 battery and then use it in reverse to connect the B300S to an AC300. The B300S can deliver 4500W, which is more than the AC300 will pull so the smaller gauge cable will work fine for it.
Does the STOCK cable in the B300s box not allow it to connect to the AC300?
I see on BEs website the P150D to P090D (to connect B300 battery pack to AC500), but can't determine if it is needed instead of what comes with the B300s to connect it to the AC300.
The cable that comes in the box with the B300S is P150D on both sides, since that is the connector on both the B300S and the AC500 (150 Amp rating). The B300 and AC300 have the P090D connector (90 Amp).
