MrPsychedelic
So my plan was to use an MPP Solar LV6548 Hybrid for my inverter and solar charge controller. Then I was thinking of using the Rich Solar version instead based off price and I've used their products in the past. I am also considering a Victron system, but I know that would be considerably more expensive, just the solar controller would be able the same price as the other AIO's.
I am going to be running (5) 540W panels. I planned on doing 3s2p, but if you guys think its better to just run 4 panels I can try and sell one, or keep as a spare. They are going ontop of a box truck. If I run 4 they will be connected directly to unistrut level with the roof. If I run 5 they will still be connected to unistrut, but it will be 10" off the roof, connected to the unistrut secured directly to the roof. That is so I can have my air fans on the roof to circulate air, and remove humidity from the shower.
I am making a 16s2p battery, so it will have 29Kwh of storage. I would rather have to much battery then not enough, so thats why I am going with 2 48V batteries.
The biggest power hog I will be running is the 9k btu minisplit, which uses around 840W, I plan to keep power useage to under 12-15kwh a day, and thats also being excessive. The inverter will have to stay on 24/7 to power the fridge so that will use a bit of power. 1-2kwh depending on which inverter I go with.
I just wanted to get everyones opinion before buying an inverter.
Thanks!
Thanks!
