sunshine_eggo
Happy Breffast!
LOL hey man that trickle of water is pretty good for a lot of countries. Many places you're still using a bucket of water and a sponge outside
Sounds like HBR when it's too cold to fill the RV fresh tank...
he had a tank? as far as I saw the pump just ran when you opened a tap / shower and shut off when it wasn't
I can see a blue pressure tank on his original pump.
Toilets can get flushed by dumping water in them. I guess they would refill on their own with just a couple PSI though. Would just take forever.
No time for a courtesy flush as you would develop hemorrhoids between the first and second flush waiting for the tank to refill.
Flying you out would most likely be cheaper then getting ripped off from Puerto Rico plumbers, honestly, if you hadn't helped me and the solution you told me, which I think I can manage on my own, I would fly you out there.his pump before probably was easier to turn and it probably had no check valve on it
the regular brass check valves he has are probably 4.5+ psi to crack them open which means he needs 10.35 feet of water height in order just to barely open the check valve. Thus it isn't flowing
by using a better check valve and a bypass, he can avoid the pump and the harder to open valve entirely. So the water will have better flow
Fly me out there and feed me and I'll hook it up directly to that line feeding the cistern and put an accumulator tank so it keeps pressure lmao
yeah the last pump I guess didn't have a check valve so I guess water could run back? I have no idea, I just know that it worked without power at a minimal flow through, since then I have learned a lot, but still not by any means great at this stuff as you guys can tell.his pump before probably was easier to turn and it probably had no check valve on it
Yea I'd expect you to get the same or better output than your old pump with no power with the grainger check valve I posted.yeah the last pump I guess didn't have a check valve so I guess water could run back? I have no idea, I just know that it worked without power at a minimal flow through, since then I have learned a lot, but still not by any means great at this stuff as you guys can tell.
hahaa I'd expect it to be cheap for that there but guess not x___xFlying you out would most likely be cheaper then getting ripped off from Puerto Rico plumbers, honestly, if you hadn't helped me and the solution you told me, which I think I can manage on my own, I would fly you out there.
Yea an accumulator tank you said it was a well pump so that makes sense. If you don't have them they short cycle and kill the motor fasteryeah the thing is, I don't want to have guests, or tell them they need to get a bucket and pour it into a toilet, and yes the last device did have a blue pressure tank.... Is that what gave me PSI during a power outage and I just didn't use it all up and maybe I am wrong about the pressure from just the downward pressure from the cistern. I surely hope not.
Why use battery power if it's just as backup? Literally just for backup nothing else?My goal is to get the entire unit on battery power, or propane, if anyone wants to help me with that, I will wine and dine you and fly you out. Issues I have - very limited space for solar, so the batteries would have to charge from AC most likely. I think propane would be cheaper due to this and last a lot longer. But I have no idea how to do this.
My place is in Condado, it is a tourist trap and very expensive. Prices for food and everything else is the same as California, if not more because they have to import a lot of stuff.Yea I'd expect you to get the same or better output than your old pump with no power with the grainger check valve I posted.
The valve is very low pressure to open
they probably have local prices and "regular USA folk" prices
Work for food is how I've done work in several countries & like 20 different states. So if you do need help just feed me lmao
when I bought the place it came with the blue pump, so it was always there. It broke just like everything else in the apartment. So, blue pump was there, replaced it with this booster pump.Can you clarify.
Did you have NO pump and then you installed the blue pump and it failed and you had the newest pump installed or did it always have the blue pump?
ahhh that I guess is making more sense, so the money doesn't really matter as much as having a fancy place that doesn't lose power / waterMy place is in Condado, it is a tourist trap and very expensive. Prices for food and everything else is the same as California, if not more because they have to import a lot of stuff.
