Mrdanielmh
- Apr 19, 2020
- 177
Nope still dead!@Mrdanielmh did you get to the bottom of this?
Thanks mate, I've tried a few different phones, including one it used to work on. Same issue. I've actually bought a drop in cause I needed it resolved quickly, so got it in the garage at the moment, will see if I can get it fixedI have multiple JBD BMS units, and the blue tooth modules can be finicky with different phones depending on what version of the BT you are using. My older LG phone cannot access one of my BT units, but another phone has no issues. Ensure your GPS option is enabled on your phone. Mine will not connect to the BMS unless the GPS is active. I suggest trying another phone or device if still having issues connecting. If that does not resolve the connectivity issue, get a new BT module for the BMS.
Did you ever have any luck fixing the issue? Mine won't show up after a dead battery (recharged now). I however javelin a solid blue led on my bluetooth module, but it still won't show up on the app (tried an old phone that worked and still had the app installed... no luck)
Sorry, should have clarified better. After the recharge my battery does output power to the trailer (so good output voltage through the BMS), and the Bluetooth light is solid blue on the module. However, there is no Bluetooth signal output being detected by any BMS app or even any BT signal reader app.Check this message out in a previous thread. It has one of Will's videos that shows a way to wake up a BMS. Maybe it will help...
New 8S BMS at 4.0V while LFP is at 26.3V. Is BMS in Sleep Mode?
The BMS is new, JBD AP21S001, and is connected to 8 new cells, Eve 280 Ah. I was able to decipher the wiring instructions, thanks to some interpretation from members of this forum. The cells are within 0.1V of each other and have not been either charged or depleted yet. The only charger I have...diysolarforum.com
L
Thanks for the help. If I remember from before, a solid blue light means it has a bluetooth connection right? My light is solid as soon as I power the bms on, as if it is locked to a previous connection that no longer exists (could be completely wrong). Is there a way to "hard reset" the bms, or is there no real memory that this thing could be locked in with right now?
