That's not the problem blueooth is working with other app just can't set the parameters.Are you close enough to the battery? Maybe there's something wrong with the Bluetooth dongle...
If you're having the same issue with multiple devices, the common denominator is the battery/Bluetooth module...I have also just downloaded and paid for the smart bms utility app (ios) for the old ipad. It finds the bms in devices but again no data transfer. I will write to overkill and see what they suggest.
It is the overkill 120a 4s purchased directly from overkill in the US.Which BMS is it and where did you get it from?
Do you know anyone else who had a JBD .... or maybe even someone with a newer IOS phone?It is the overkill 120a 4s purchased directly from overkill in the US.
I'm confident overkill will take care of you.It is the overkill 120a 4s purchased directly from overkill in the US.
Just downloaded and installed on my wife's iPhone 15 Pro. Connected just fine.Do you know anyone else who had a JBD .... or maybe even someone with a newer IOS phone?
Need to determine if the problem is the BMS or the APP.
So it is possible the sense leads are functioning but no guarantee the protection is working correctly. The reason I ask is I can't risk testing over voltage or under voltage with the shipped presets of 3.65 and 2.5. So I really am stuck until I can resolve the communication issue correct?I would that confirms the sense leads are working.
Everything looks good to me.I guess this answers my question...
OK. thanks again. I've just had troy from overkill on the phone and he is happy to send out a new module. Fingers crossed I will be up and running soon.Eve
Balancing won't turn on until cells reach balance voltage setpoint.
It's good protection isn't showing, it would only show if there's a fault.
