CATL 16S 11kWh battery Pack, is this LiFePO4??
GibbFx
Modena - Italy
Hi everybody,
I follow the forum from Italy, and sadly from Europe is almost impossible to buy Server Rack Batteries ( from signaturesolar, I mean).
To tell the truth, this forum is a huge source of informations for me!
In my 48V system, I found an interesting solution from CATL; according to seller it's a 16S 11kWh pack composed of prismatic cells.
Has anybody any experience with this battery pack??
Any clue if the modules are LiFePO4 or other kind of chemistry?? (in some site I found it could be Li NMC, but from the pictures looks primsatic cells... I'm a bit confused)
Can anybody help me out with that??
Thank you guys...
Ok, maybe this can give some help:
it is rated:
Nominal = 3,67 V/cell (58,72 V/module)
Max Charge = 4,2 V/cell (67,2 V/module)
Cut off = 2,8 V/cell (48 V/module)
from this data doesn't look LiFePO4 I think, but still... they look so prismatic...
Check out nkon.nl or fogstar.co.uk - Both will supply to Italy AFAIAA.
it is rated:
3.7V nominal per cell is definitely not LFP. Also that's almost 59V nominal, at 67V at max charge - not going to work with a 48V system.
LFP nominal is 3.2V (so 16S is about 51V nominal).
