A few points.It’s always better to use real life data , hers a Winston cell (LFP with Yttrium added ) data sheet graph , note Winston specifically statenthstvtge cell will be damaged if charged above 4v
note that 100% SOC is reached at 3.65V. Greater then that leads to over charging ( > 100% SoC ), but lower C charging results in more energy being stored
I hope nobody gets the idea that its ok to charge an LFP cell to 4.2 volts.I am not following. If you do a search on LiFePo4 charge curve you will find many versions of this chart. Granted, we never take a cell to 4.2 volts but that is what the charge curve looks like.
Thank you for the feedback.I usually see this happen on packs built with non-matched raw cells.
A good solution is to stay on the back side of that charge knee. Somewhere between 3.4v, and 3.45v
I should probably add something about matched and unmatched cells. Most of the comments in the document have an unstated assumption that you are starting with reasonably matched cells.
Most of the first timers here don't know that matched is a thing.Do people assume they are matched?
sorry that doesnt make sense , the cell that reach’s the top balance voltage setpoint , ie the cell with the lowest energy capacity , will trigger the balance activity , what then happens is energy is diverted away from that cell , in theory this allows the charging process to continue , ie the other cells with greater energy capacity to “ catch up “ . most Times the diverted current is less then the cell charging current , so some charging continues on the low energy cell. Usually it still reaches the cutoff voltage before the other cells , and hence remains partially out of balance , but the next balance cycle , or in a few , will typically bring the cell into full balanceThanks for the feedback, but unless I missunderstand the comments, I disagree.
In a top-balanced battery, the voltage on a weak cell will start dropping before the other cells and will eventually cause the BMS to shut off while the other cells still have energy.
In a series configuration yes to a point , this is a function of BMS protection rather then the battery config , your thought experiment is often the reason why parallel “ first “ cell configurations are better then series first. By rearranging this battery as a parallel first orientation , you mitigate the problem to an extent , because paralleled cells of different capacity share the load more or less.Here is a thought experiment: If I build a top-balanced 12V LiFePO4 battery out of two 100Ah cells and two 200Ah cells, what will the Ah of the battery be? The answer is that it will be a 100Ah Battery. The 100Ah cells will start dropping in voltage and shut off the BMS while the 200Ah cells still have half their charge.
If there are parallel cells within a single battery, the BMS sees the parallel cells as a single mega-cell. In this case, the capacity of the mega cell is the approximate average of the parallel cells. (the capacity of the Mega cell is not defined by the weakest cell, but the capacity of the battery is defined by the weakest mega-cell)
Note: For series batteries, the weak battery does define the total energy of the system just like series cells defines the capacity of the battery
For parallel batteries, the weak battery does not define the total energy of the system just like parallel cells does not define the capacity of the battery.
what you need to make clear is this is a single cell series battery ,Even before your comments, I had decided I needed to add clarity to this page and updated the diagram to this:
Perhaps I should also add an annotation about the BMS or Loads cutting off. I should also point out the dashed part of the red line represents the unused energy of the other cells.
there is no such thing , why would the voltage “ suddenly diverge “. This would only happen in an extremis situation, ie damaged or life expired cells , or cells that have widely different energy densities arranged in a series string.Fair enough, I will define it in the doc. In the meantime, by 'run-away cell', I mean a cell that has a voltage that quickly diverges from the voltage of the other cells.
I guess I need to add a bit about balancers.... but I worry it will be a confusing tangent.Again what’s this term “ run away “ , are you talking Thermal run away
top balancing is problematic if you can’t control charge currents as you simply run out of time to draw energy out of the highest voltage cell all the while charging continues , so unless the balancing current is exceeding the charge current the time ( which is unlikely without charge current step back ) then the out of balance cell will continue to accept net charge current and it’s terminal voltage will rise , since your top balance start voltage is so close to your cutoff voktafe you simply run out of balancing time.
It is a bad idea to run a balancer of any kind if the cell voltage is much below 3.4V. The balancer is using cell voltage as a proxy for SOC, but in the flat part of the curve, the cell voltage is a piss-poor indicator of SOC. In fact, a cell measuring 3.25V might have an SOC that is higher than a cell measuring 3.28V! If a balancer tries to balance the voltage between these two cells it will actually screw up the top balance. This is why the default turn-on point for balancing on a BMS is almost always around 3.4V.active balancing has the advantage that no energy is wasted , you can in theory , run an active balancer , all the time during the charge process , you can even run it in discharge ,or during battery rest , this means there’s a far longer potential balancing time. Also the nature of switched capacitor balancers is they are higher current capable then resistive balancers.
this is not what Texas Instruments and others define as a runway condition , a cell imbalance runaway only occurs where a weaker cell is exposed to uncontrolled series charge cycles resulting in repeated over voltage situations , this further weakens the cell and the cycle repeats until the cell is destroyed . This cannot happen in BMS protected cell charging as the cell is not ever overcharged and hence there is no significant further divergence. I have quite a bit of collected data on series cells, used in fractional C situations , They do not tend to diverge significantly over time , yes unbalanced cells cause loss of energy capability but its wrong to suggest that there is a rapid divergenceFair enough, I will define it in the doc. In the meantime, by 'run-away cell', I mean a cell that has a voltage that quickly diverges from the voltage of the other cells
The page we were discussing was about discharge and the end of the cycle. At that point, the balance is not involved (or at least should not be)sorry that doesnt make sense , the cell that reach’s the top balance voltage setpoint , ie the cell with the lowest energy capacity , will trigger the balance activity , what then happens is energy is diverted away from that cell , in theory this allows the charging process to continue , ie the other cells with greater energy capacity to “ catch up “ . most Times the diverted current is less then the cell charging current , so some charging continues on the low energy cell. Usually it still reaches the cutoff voltage before the other cells , and hence remains partially out of balance , but the next balance cycle , or in a few , will typically bring the cell into full balance
OK..... My definition is what I have always seen on this forum.this is not what Texas Instruments and others define as a runway condition ,
my point is that run-away is a self perpetuating circumstance, rather like a " chain -reaction ", ie thermal runaway , where the heat generated itself fuels further runaway . IN a BMS protected system , I fail to see how run-away can be applied to cell balance or cell voltage , I cant see any fault mechanism where the existence of a high cell voltage then perpetuates a higher cell voltage and so forthOK..... My definition is what I have always seen on this forum.
thetas precisely what bottom balancing is , and bottom balancing is a far better way to extract all the energy , which is why its used in EVs, top balancing is used cause its simpler to implement. The drawback is that bottom balancing requires the battery be drawn to low SOC , which doesn't suit some applicationsThe page we were discussing was about discharge and the end of the cycle. At that point, the balance is not involved (or at least should not be)
I agree that in a series string irrespective of balancing , a weak cell remains a weak cell , no amount of balancing can correct that , what balancing does is ensures the other cells get more charge time , top balancing is largely carried out because cell often have very similar energy densities but for various reasons , their terminal voltage versus SOC is different , This is all top balancing can correctWith a top-ballanced battery, during discharge, the 'weak' cell will track the other cells reasonably well while the SOC is high but will diverge when the SOC gets low. Yes, I guess if you kept discharging the battery you could get some/most of the energy out of the other cells, but the voltage of the weak cell will get into ranges that damage the cell. However, a properly set up BMS would stop the discharge before that happens.
yes but active balancing is getting more and more common and hence alternative balancing strategies may appear in time . my comments about balancing method was more to illustrate that the issue demonstrated by the OP is a function of a particular BMS strategy rather then a function of the batteryThis forum is primarily about DIY storage batteries used in solar applications ..... it is NOT about EV's. Most DIYers on this forum are also TOP balancing their cells .... so, introducing all the counter arguments about what an EV BMS may or may not do is counterproductive.
I didn't say it was about thermal runaway , I made the comparison that using the term runaway was inappropriate . The issue being discussed is more correctly described a cell imbalance issueThe topic of this thread has nothing to do with thermal run away. Run away is being used in a different context here. It is a bit confusing, but once it's understood that it's not about thermal run away, it's OK. Other possible ways to title it could be "Cell Voltage Deviation" or "Deviant Cells" (I like this one, lots of eyebrows will be raised over that!).
I think that it's acceptable to assume that the cells in the pack are all the same Ah specification. Otherwise, the discussion could get rather complicated. We're trying to help the new guys troubleshoot. Too much into the weeds and we'll lose them.
I'm a firm believer in the KISS methodology ... when possible. Over time, this forum has generally concluded that the most simple method for most DIY packs is to top balance and then try to maintain balance by only balancing above 3.4V.yes but active balancing is getting more and more common and hence alternative balancing strategies may appear in time . my comments about balancing method was more to illustrate that the issue demonstrated by the OP is a function of a particular BMS strategy rather then a function of the battery
agree its certainly commonI'm a firm believer in the KISS methodology ... when possible. Over time, this forum has generally concluded that the most simple method for most DIY packs is to top balance and then try to maintain balance by only balancing above 3.4V.
why is balancing under 3.4V bad in itself , Active balancing is superior in all balancing methodologies and has become prevalent in any sophisticated solutions especially switched capacitor designs and may cheap BMSs now use active balancing . Passive balancing is very wasteful in many cases , especially where power generation is limited . Top balancing benefits from active techniques.Active balancing is a hot subject and people have their own strong opinions. I tend to think that if cells are top balance and capacity matched active balancing is not necessary .... I also believe that balancing below 3.4V is a bad idea MOST of the time.
unless you examine the shibboleths , you never build a first principles understanding of why things are done the way they are and the tradeoffs . The lack of discussion leads to blind obedienceSome just like to argue for the sake of arguing with no real concern of whether it is productive.
