Needing some help figuring out a chargery Bms. I'm in the process of a series precharge prior to a top balance. Following the manual everything seems to work fine untill I adjust the AH and WH. Its factory set at 20AH and 1000WH. I have 280AH at 7160WH. Once this parameter is set, the bms pegs at 100% SOC and begins to cycle the charge. If I reset to the factory settings or make any adjustment to the AH or WH the SOC remains at 98-100%.
I have 2 8S Chargery and both do the same thing. Been charging for 18 hours and the batteries are approx 3.4v so its not near a full SOC.
