Quick question here: ( and yes I know it's wrong to do so but needed a bit of a quick McGuyver solution)
I have 2 large 12v lead acid batteries in series to get a 24v system. Due to circumstances I needed to supply extra power for my 24V application but only had a little 12v charger at hand. I connected that charger to one of the 2 batteries and started using the 24V hydraulic pump.
As said, I know you're not supposed to do so, but is it not true that if you charge 1 of the 2 batteries slowly, the 2 batteries start to balance ? I mean one can not really have a much different voltage then the other, not?
It wasn't a big ass booster charger pushing the amps in, just a small battery charger that goes to drip when done. Is it really that bad that I am damaging the batteries ? (Not planning on doing this to often )
Thanks for any replies
