PfloydBham
- Dec 27, 2019
- 54
I am something of a novice so can I get some advice? I built a plastic ammo box battery with 18650 cells from modems as a 4s configuration which charges to 16.8 volts. I put a small socket in the lid which has two USB charge ports and a small volt meter as well as a cigarette lighter socket and an on/off switch. I intend to power led lights that run in 10 to 30 volt range so the 16.8 volts is workable with them. But, I really do not know much about how the chinese USB ports are regulated. Is it likely that I can plug a fone or tablet into the USB safely, or will the voltage be too high? Any thoughts would be appreciated, thanks.
Pink Floyd
Pink Floyd
