I recently ordered and installed a 24V LiFePO4 battery bank on my garage power wall for short term/grid down backup. I connected 2-12V in series and have a 2K inverter and a 24V charger connected. All seems to be working ok right now however after I built my system I discovered through additional research of the conflict of the 24V charge and independent 100A BMS on each battery...ie, if one fills up faster it shuts off the charging circuit for the other. Equipment is as follows...2 x Ampertime 12V 200A batteries with a Progressive Dynamics PD9140-24ALV converter. The inverter is a Samelex 2KWh but really is not part of the dilemma. I'd like for the system to require little interaction from me...just be there when needed. Should I sell the 24V converter and install 2 12V converters to charge the batteries independently? Is there some device that can sit in between the 24V converter and batteries to distribute 12V charging independently? (these will also be charged with up to 1200W of solar, charge controller in hand, but I'm now holding off on finishing until I figure the charging scenario)
