Hi
First time poster, so tell me if I am on the wrong part of the board.
I am working on a small project. I want to charge a mobile lithium ion battery which is 36V10ah, with a lead acid battery which will act as the battery bank.
I know I will need my lithum Ion battery charger and an inverter to do this. But my question is the size of lead acid battery I would need, I am going to use a SLA or Gel cell.
I want a lead acid battery that will have at least a life of 5 years. I also want the size of battery that can fully charge the lithium ion in one sitting without being damaged by the depletion, so a slightly larger capacity of lead acid than the lithium ion.
Can you tell me what size lead acid i would need or how I should work this out.
thanks
Rob
thanks
Rob
