Hi all,
I have a 6500EX inverter. I'm currently running 8 x 210W panels in series. I know that it is good practice to only put matching or similar voltage panels in a series string.
I want to expand my system with some larger panels, and curious as to the best options. Can a combiner box be used to combine strings of different voltages and then that feeds into 1 mppt? Is it better to run a second independent cable back to the inverter and put the added panels on that as a separate string for MPPT 2? That is more copper to run for sure. I'm assuming though that the 2nd mppt on the 6500ex can be totally different voltage that the 1st?
Thanks for any advice.
