Would someone knowledgable please look at the circuit and tell me if its safe or has flaws or needs moifying before i turn on and possibly find out the hard way .
The Lithium battery is sufficient to cover our normal consumption between the hours of 6pm and 10am , when we have bad weather and the main batteries are down to 50% , we use 70% to 85% of the Lithium batteries capasity . The reason for this set up is that until now i have to start a small Honda EU22i generator and run it at night for about 3 hours but even tough the generator starts after only 1 or 2 pulls im finding even that a struggle leaving me breathless , the wife cant start the generator but she can turn a switch . Only had 4 occasions so far when we needed to use the Backup battery but i have been manualy removing the positive input to the Inverter from the main system Busbar and attaching it to the Lithium battery and the reverse the folowing morning . Until we reconect the Inverter to them main systems BusBar the MPPT charges the Main battteries as normal .
I keep noticing continuity between places i would not expecy to see it such as between the terminals on the changeover switch that are not selected and between the input to the switch and the inverter positive when the switch is in the OFF position and also between the BusBars , the switch is new sand functioning fine and i have bought another to check and also when its not in the circuit there is no conuity where there shouldnt be . Removing the Lithium battery makes no difference and i am positive theres not a short anywhere .
