9min into this video
He basically says more cells is more force..
For example, if I added more weight to the rig I used to do my testing of my springs, then the spring would get shorter because there was more weight on the spring. Therefore at the ends of the springs there is more force/pressure being applied.. Now if those same springs are used on my 19cell pack, then as the 19 cells expand (up to .5mm each) the spring would get shorter. Then the same as I just explained happened on my test rig would happen,, more force/pressure would be applied to the cells because at the ends of the springs there’s more force/pressure being applied do to the expansion of 19cells and how much shorter they made the spring get. Now the kicker,, IF THOSE SAME SPRINGS were used for 1 cell (not 19) the spring would NOT get nowhere near as short as it does with 19 cells. Now if it’s understood the shorter the spring gets the more pressure/force that’s applied, then there’s no way it can’t be agreed that there should more pressure/force in the 19 cell rig than the 1 cell rig..
Yes I understand to use different size springs to make sure the pressures/forces are the same in a 19 cell or 1 cell pack.. but that doesn’t change that more cells are causing more pressure/more force (due to the additional expansion length) in a fixed fixture that can’t change its springs because it doesn’t have any..
