I have a 12v system utilizing an 800ah battery bank and my goal is to use a 1/4 inch by 1 inch wide copper bar as a bus bar to connect the positive terminals and then negative terminals appropriately. My question is if the 1/4 inch by 1 inch wide copper bar is enough to support my system? I’m struggling to understand how I would determine if these bars are correct or if I need to go with something thicker or just use 4/0 cables like most everyone else. The system is connected in parallel. Thank you in advance for any guidance!
