Would be even more interesting if you identify each axis, units, and each dataset on the chart.
kW and TimeWould be even more interesting if you identify each axis, units, and each dataset on the chart.
Hey James I am curious what brand/model of 4 ton AC are you using that its pulling under 2000 watts? I would also like to see a daytime graph as that appears to be overnight. I have a similar graph but when my 4 ton AC (with microair easystart) still ramps up and consumes roughly 3500 watts running and yours looks to be consuming much less. My system is about 10 years old and I have been researching an upgrade.
My 10 year old economy 2 ton compressor pulls 1,500 watts. Plus another 400 watts for indoor blower.Hey James I am curious what brand/model of 4 ton AC are you using that its pulling under 2000 watts? I would also like to see a daytime graph as that appears to be overnight. I have a similar graph but when my 4 ton AC (with microair easystart) still ramps up and consumes roughly 3500 watts running and yours looks to be consuming much less. My system is about 10 years old and I have been researching an upgrade.
I'm assuming red is grid, is that correct?
Two speed? SEER rating?
I’m seeing two power supplies or two legs of the inverter each supplying roughly 2000w when AC is runningHey James I am curious what brand/model of 4 ton AC are you using that its pulling under 2000 watts? I would also like to see a daytime graph as that appears to be overnight. I have a similar graph but when my 4 ton AC (with microair easystart) still ramps up and consumes roughly 3500 watts running and yours looks to be consuming much less. My system is about 10 years old and I have been researching an upgrade.
I’d suspect its short duration backfeed to the grid before the inverter has time to react as loads shutoffI'm assuming red is grid, is that correct?
What's up with the ripple on the right side and blips on the left side?
How much any heating or cooling system cycles power on/off depends on the thermal properties of the dwelling/space being heated/cooled, the temperature differential inside to out, the unit's output capacity relative to the space being heated/cooled and the type of controller. Some units are also capable of running at different power levels rather than simply on or off.Is that cycling I see? When it gets hot mine just runs straight through to 5am. IIRC mine is 3ton pulls 2kW.
Thats more in line with my 4 ton at 3500w not including the air handler. At night we just use mini splits in the bedrooms and air handler on circulate so I rarely see the big boy fire up at night. During the day I have the air handler fan on, mini splits on, and at 100 degrees the Central air will only cycle every 30-45 minutes. Thats the best way I've found to trim my usage here in southern AZ but I asked the original question of @SignatureSolarJames because I am considering replacing the central unit next winter.My 10 year old, 3.5 ton A/C takes just over 3kW to run, and that doesn’t include the air handler.
This is what I learned...it's time to upgrade my 12 SEER Air Conditioner.Someone check my math, but for 4 tons of cooling performance to draw 2kW you'd need a SEER of 24.
I'm surprised that your geothermal pulls 2K. Does that include inside air handler and does your geothermal also provide hot water?My 10 year old 2 1/2 ton geothermal unit, pulls right at 2300 watts (on stage 1). Very hard to imagine a 4T unit pulling only 2K watts, even on stage 1 (if it is a 2 speed compressor). Does the data include the outside condenser unit draw as well? Something doesn't look right.
