I never expected that my two 24vdc / 270-watt Renogy solar panels totaling 540 watts would be enough while providing power for my 24vdc 3000-watt inverter. I had fully expected that I would need to add additional panels up to roughly 1.1k watts of solar potential before my power needs would be adequate. I also did not expect that just two 100 amp hour batteries would be enough storage for overnight use. That was before I installed the 9000btu Pioneer mini-split A/C - heat pump unit. That was indeed a game-changer.
Now I have excess power generated from the panels from 9am until 7pm in the summer. My two 100 amp-hour batteries remain at 100% fully charged during those hours (overnight they never get lower than 85% capacity). That is with the mini-split keeping the inside temperature a approximately 78 degrees Fahrenheit from roughly 10am until 7pm. The mini-split is operated in “eco mode” which is perfectly adequate for this small space that is not properly insulated as yet. All the time that the A/C is running the solar panels are developing enough power to keep the batteries at 100%, to keep my small fans running, to keep my vent fans running in ceiling fan mode, to keep my electronic equipment charged, run a microwave occasionally as well as run my 32” LED flat-screen streaming videos. The solar array simply stops developing more than approximately two-thirds of its capability as there is no place for that power to go. Seems like a waste.
So here is that challenge; how do I store more power? I could add more batteries and store more power in batteries. I really don’t see the point in that as once the batteries are at 100% the Renogy 40 amp MPPT charge controller stops significantly charging the batteries. That would be true regardless of how many batteries that I add. The charge controller simply places the batteries in “float mode” or “boost mode” or occasionally “equalization mode”. How do I store more power? I believe that I have the answer; run a 5 cubic foot freezer during the day and freeze one-gallon jugs of ice solid. The freezer would remain off at sunset and be turned back on at about 9am the next morning. If that is not enough I will buy an ice maker machine and make about 10 pounds of ice a day to fill my ice chest. Between the “block ice” that I make in the freezer and the cube ice that I might make in the ice maker, I could keep myself in smoothies indefinitely as well as run a blender and masticating juicer.
I realize that my solar panel and battery storage needs might change with the seasons but I am not so sure. I am in New Mexico at an elevation of 6500’ therefore we get plenty of sunshine in the winter albeit shorter days. The mini-split heat pump uses less power than its A/C function. I will use supplemental heat such as a small wood/pellet stove and catalytic propane heater. I will also employ solar hot water before winter that will be cycled through to keep the floors warm. The only variable here that I can see is the number of cloudy days in winter and during the monsoon season. I don’t think that is an issue as I can always bring my batteries up to a full state of charge using the 2kw inverter generator that I very rarely use.
BTW: this is all done off-grid in my homemade RV (see pic). I live full-time in the forest on dispersed camping public lands.
