The story...
I have an off grid cottage with two 265W panels on the A frame style roof.
They provide power to a midnight solar Kid controller, and 4 GC2 golf cart batteries wired for 12V.
This feeds the inverter which puts out 120V AC and everything has worked fine for 5 years now.
Runs the lights and a mini fridge freezer, radio
My plan is to add more panels on a different section of the property about 100 feet away from the cabin.
i purchased 3 x 400W panels and plan to wire in series (100V) to help cover the long distance.
These new panels would be oriented at 90 degrees to the original roof mounted panels.
Roof panels get sun from 9am to 1PM, then almost nothing due to trees.
The new panels would be facing lake and get light from 1PM to sunset.
Can this work with one Kid controller with 30 amp, 140V max rating?
does battery voltage factor in to these limits?
Diodes on both arrays required?
I know Im oversizing the array. but expect to add future appliances which will draw off extra current.
Anyways, thoughts, opinions, expert advice?????/
Thanks.
Thanks.
