Johno1066
Surface to surface connectivity, there will be more good contact with a soldered lug than a crimped lug and if the soldered lug is crimped it will still have superior surface contact with a greater mechanical strength.
My uncle loves his lead acid setup and will likely never make the switch to more modern energy storage...that being said, I assume a more corrosive environment is made when wires are around off-gassing lead acid batteries. He ALWAYS crimps and solder seals his joints with a silver solder. Also he's worked professionally in the automotive business for 30 years. I think it's overkill for most installs in non corrosive environments, but for longevity he swears by it and never has to remake his wires again.
And so do does an extreme pressure crimp joint, where the malleable metal actually flows and fills any voids, keeping out the contaminants.
I have a couple pair of different iwiss crimpers that are ok with 10ga through 16ga and the BougeRV the do ok for 8ga-12ga MC4 terminals. All ‘B’ crimps.I hydraulic crimp anything 10 gauge or smaller now and have always crimped 6 gauge or smaller in the past. I loath trying to crimp the smaller stuff since it requires using the pliers style crimpers and usually solder it since I can't get small non hydraulic crimps to work worth a flip.
I have one and I have used it on 2/0 and 3/0 but you sorta have to do three or four stages to get an acceptable crimp imho; one mighty wack with a 3lbs hammer will do the deed but not nicely swaged as I’d like. The hex crimpers for ~$35 do an acceptable or excellent job 99.44% of the time.just get the impact crimper.
It does a good e'nuff job
I use the bicep-builder pictured above for 1/0 through 6ga. I can ‘progressively’ finagle them on 2/0 but I think I’m ruining them doing that.
The esthetics is not my concern. It’s 100% contact that interests me.Heat shrink hides the ugly.
Solder is for small electronics boards. Power transmission should be crimped only. Otherwise we would be soldering our home wiring.
That’sa great idea.This can also be mitigated by using 2 shrink tubing layers.
Well that’s funny to me ?Mechanical clamping devices hold household wiring, not crimps.
Traditionally, my argument for wiring incorporates three elements: mechanical connection, electrical 100% contact, and environmental durability. Ptoper crimping and heat shrink sorta does all three simultaneously. A crimp is mechanical clamping.
I have found that to be the case on virtually every wire over a few years old for the past 55 years I've been soldering various bits and bobs. I suppose I have enough experience at this point to be considered something of an expert. I've never really researched it but I would think the gas permeability of the insulation plays a role. Not to mention that I've replaced cables on wet cell battery banks fairly often. I have high hopes now that I'm using lifepo4.That’sa great idea.
By the way, I recently found some 2awg cables I had crimped then soldered. Corroded and oxidized nearly all the way through the 2 feet of cable. My solder skills are poor and I’m pretty sure I overheated the wire. Just a warning to those who haven’t perfected their soldering skills…crimping is easier even if it’s not quite the best.
