Bob B
Emperor Of Solar
- Sep 21, 2019
- 8,633
The discussion came up on another thread about whether or not current flows to the bus bar thru the stud. That discussion was surrounding the use of the stud / flange nut type of connection using a stainless steel stud and nut and an aluminum pad on the battery cell.
I wanted to separate the discussion because the original discussion was being somewhat side tracked.
I have seen it reported a few times that there is no current flow thru the stud .... only from the pad on the cell terminal to the bus bar .... I don't agree with that and would like to see some more discussion about it. I would argue that when a parallel circuit exits, current will flow in all paths. The amount of current flow in each will depend on the amount resistance in that path.
Some things to consider:
1. Is there any way to scientifically determine how much current flows .... or how much resistance there is in each path.
It seems to me that there are so many possible variables it would be hard to determine.
2. How would the contact resistance of the pad and stud connection be determined? It seems to me this could vary wildly depending on how well the surfaces were prepped.
3. How would the contact resistance of the stud threads to terminal be determined?
4. How much difference would the torque on the nut make ... both to the cell pad connection and the thread connection?
5. How much greater resistance would the stud have with that short of a connection point?
6. How would the application of something like Noalox affect the contact resistance. Even though the Noalox will help prevent oxidation, the substance itself seems to be an insulator.
7. How much different would the flow be when there is a ring terminal attached to the top of the bus bar? The main positive and negative will have a lug attached to the top of the bus bar which will add an extra point of contact resistance between the pad and the lug and make current flow thru the stud more likely?
8. How much difference would surface area make on both the pad and stud ... for instance if the stud was screwed in more or less, for instance.
9. How much difference would temperature make?
10. Is that bus bar really flat?
11. Using @HRTKD suggestion .... is the top of the cell terminal pad really flat?
There are probably more variables you engineers can dream up ... kinda hoping there is someone who specializes in these kind of calculations.
My premise is that even if the resistance of the stud to bus bar is 10 times greater that significant current can flow thru the stud. If 10 times greater and current flow of 100A ... the stud would still see 10A .... and it seems to me the stud would carry more current when there is a lug attached.
For those who want to read the comments already made on the original thread about studs, I am posting a link if you haven't seen it ... but please post current flow comments here.
link to proper studs and nuts for eve cells?
Anyone have a US link to high quality proper studs, washers, and nuts that fit the eve 280ah cells? Also any clue to proper torque and seat depth? Mine came with crappy bolts and I want to replace them.
diysolarforum.com
