That is exactly what needs to be done! Then it would be possible to fool the SP2/3 into thinking it has an original BMS. I'd do it but I've not much spare time at the momentI think it might work for your one @Timrees that was reporting PV short circuit. If you've any spare broken ones with different error codes , feel free to PM me and I'll give you my address. @Geoffito is kindly donating an SP3000 to the cause, before long we'll have a full library of repair manuals ? ! I might have a crack at decoding the RS485 comms to the BMS next. I reckon I could use an arduino as a 'man in the middle' and record the conversation.
Check that pack over. I've had 2 cell packs go bad, and there was obvious battery leakagethe one pack was down to 0.80 volts today.
Hi Guys, been doing some more experiments today with @Geoffito 's SP 3000. I was hoping the SP 2000 had a rather primitive charge algorithm, and the SP 3000 would have a much sharper response time, but alas no , it's exactly the same. The algorithm appears to be... if grid < -100W then increase battery charge by 5.8W per second until 0W > grid > -100W ; HOWEVER if Grid > 0 : reset charge power to 0.
Which is really poor when a cloud passes for a couple of seconds because it wimps out and goes back to square one....e.g.
Yellow = power SP 3000 is sending to the inverter
Green = Grid power
(unfortunately I've got no sensor on the battery power...but it's easy to work out )
So in this example at
14:00:00 : the skies cleared, sun came out , and I'm exporting nearly 1kw to the grid. ZERO watts going into the battery.
SP3000 gradually increases power to battery , and reduces power to inverter.
14:03:00 A 700W load disappears from the house usage....probably the wife switching off the hoover
14:07:00 7 mins after the Sun appeared, it's finally ramped the battery charge up until we're only exporting 40W or so
14:11:00 Tiny cloud passes, SP3000 shits its pants , resets charge power to 0.
14:12:30 Suns back out, The sloth like ramp-up cycle begins again.
If you look at the amount of energy pumped out to the grid here , in this 30 minute snapshot it really shows how inefficient these units are.
I've had a reasonably sunny day here, yet the GBLI5001 is only 49% full.
Good spot , that'll explain that then.On the Growatt Spec sheet 45 Amps is max output for Growatt GBLI5001.
Dunno Trev , proper headscratcher, I'll plug the RS232 in tonight and have another look at the SP3000 settings. I'm gonna leave the SP2000 in overnight and see how that does on a discharge cycle. Good news is the battery is at 99% now so can get a full discharge and see what that looks like.Mmm mystery that paul is there a percentage charge and discharge setting that might be set quite low at the moment on my sp-2000 I set mine to 95% As Anything above that fries the Anderson plug until I get a new one fitted that is
Look below
Sorry Ismaiel , forgot to reply about this, I did briefly see your REC BMS stats , but they vanished now. I've no idea on your REC BMS or Inverter model , but I do remember the balance image you had up before was WAY out , I think some packs were 3.6V while some were 4.2V. They're meant to be within a few mV of each other, 3.6 is almost flat , 4.2 is full, so I'd get the meter out, Charge it to full, check each pack, take a snapshot of the voltages, leave it an hour , check again ..... some of the packs must be faulty / losing charge.SOC is suddenly dropping from e.g 70% to 2% voltage still 49.81v
To sum up todays experiments, at the end of the day, comparing back to the sunniest day last October...
Last October : Energy generated 12.5 kwh, Energy used = 15.8kw
This October (with battery) Energy Generated =11.1kwh Energy Used=9.8kwh :-
And I had it AC charging from 4:24 (MCB reste) to 5:30 today,
So batteries are worthwhile in the long run.To sum up todays experiments, at the end of the day, comparing back to the sunniest day last October...
so that accounts for 1 extra kwh.
you can get a 14S 300W charger for about £30..... it'll probably take about a week to charge though given the size of your pack.What type of charger is can I use, to bench charge the batteries?
