DC/DC IUI charger (aka cc/cv/cc)
rbs
Can anyone recommend a commercially available DC/DC charger that has a programable IUI (aka cc/cv/cc) charge profile?
Ideally I would like one that can have a programmed voltage differential for shut down of the 3rd stage, but I would be happy with a timed shutdown as well. Would be awesome if it could go to a 4th cv (float) stage.... but beggar's can't choose...
I have only been able to find AC/DC units.
Thanks
I don't know what voltage, battery chemistry etc you are using so suggestions are a shot in the dark at best. That said there are battery chargers from Mean Well that accept AC and DC input and can be programed to modify the charging stages (with an external programmer) and the outputs can be "tweaked" by adjusting the voltage input to assorted pins.
mean well RPB-1600-48 is one such example. you can look up datasheets digikey.
I just learned about them here.
