Bud Martin
Solar Wizard
- Aug 27, 2020
- 4,844
So what does the unit do when you have clouds come and go? Does it go into shutdown due to not be able to supply enough power to the loads? Do you see it cycle on and off a lot?
All these spelling errors are so funny lol
Well the thing is these guys just buy the inverters and sell them , they dont even know what they are selling , thats why they are so cheap anyway but these machines have the functionality of more expensive inverters.
Funny thing is people pay twice or more sometimes for MPP or growatts but they are *pretty much* the same stuff, prove me wrong...
We all read the posts about how its one company that makes the designs and basically sells the designs to 2-3 factories in the same chinese city.
Just because a USA/EU distributor slaps his brand and markets it good , you think you are buying higher quality stuff, maybe a slightly different design with some better capacitors ( probably not ) , the functionalities are the same and the software too.
Thats the price you pay for cheap stuff... No or bad marketing... bad manuals , bad or no aftersale guarantee/ support...etc Its a bit more risk for sure.
But still I thought its pretty cool it has some dust filters . Other much more expensive inverters dont have dust filters or good smooth fans.
The overall build quality seems very nice if you ask me , not any different that the MPP or Growatts Ive seen. Im not talking about the internals because I don't know about that.
It only cost me 430e shipped from Aliexpress directly from the factory's warehouse in EU.
It's pretty crazy what you get for 430e , that is if the unit lasts.
I find it impressive that the unit can "blend" grid power and PV power and do it a fashion that makes the batteries pretty much useless for me.
It can even run batteryless which is pretty amazing and again you don't have to buy batteries so makes the system cheap. Many people dont get into solar panels because the inital cost is too high.
Batteries are so expensive and they don't last as long as PVs or inverters do.
For 2.3k euro I have a 3.1KW system which covers 80% of my electricty needs. ( 5000kwhrs out of 7000kwhrs yearly ) .
I know people like quality stuff but my system has a ROI 1 year ( if it lasts that long ) , getting victrons and good quality lifepo4 has a ROI of 5-6-7 years ( depending where you live ) and if you pay someone to install and do all the work in an expensive country you might as well skip install solar panels.
Sure I have to put the washing machine, dishwasher, air con and everything during day, it doesnt matter for me.
Now if it was a good buy or not , I guess time will tell .
You make good points. It does appear that it's all made in China by just a handful of factories. One only has to spend a few minutes on the Voltronic Power website to recognize a lot of brands. The colors may be different but the displays are in the same places, etc.Well the thing is these guys just buy the inverters and sell them , they dont even know what they are selling , thats why they are so cheap anyway but these machines have the functionality of more expensive inverters.
Yes, made in China or Taiwan. I thought that MPP Solar was in Taiwan ?
There are definitely good and bad products no matter where they are made though.
But what the heck is THIS ?!? Looks kind of like a washing machine or hair dryer.
It has RGB lights though so it MUST be great !
boB
I also think it seems that it doesnt output the full wattage of my panels but I will double check tomorrow , so if my panels can produce 2.5kw , you cannot draw 2kw power for a hair dryer , it seems its less, so it seems the system is not perfect , but I did manage to run around 1kw from 3.1kw panels in full sun .
I have a question that I couldn't find answer. It would be great if someone knows the answer.
The inverter has a BYPASS mode , what would be the maximum power output with bypass mode ? Is it still 3.6kw ? It doesn't say in the manual. Can I use the full 8kw(?) (230v , 40AMPS ) from the grid through AC in ? Or should I install a switch on my main panel to switch to grid whenever I want to draw like 6-7kw ?
I have a similar unit but the 5.5kW 48V version and I read this functionality different! The way I understand it is that as soon as the requested AC power is greater than your AIO can provide, it switches into bypass mode, i.e. an internal relay disconnects your internal inverter output and connects the AC input of the AIO to the AC output directly. So there is no blending or adding "just the missing required power". It also sounds reasonable that they do it that way because that way it is much simpler. Check your data sheet - mine says something about 20ms switch-over time. If there would be blending, the internal inverter would have to be EXACTLY in phase with your grid power all the time (as it does not know when your load would exceed the internally provided power) and there would be no switchover time.... so if my AC asks 1.1kw and my PV are at 1kw , it will draw 100watt from AC input ...
Regarding the maximum load you can draw, please also check your datasheet as the switch-over relay has also its limits. And I would be surprised if they would have spend a relay that can handle 10kW (230V 40A) in a unit that is rated 3.6kW.
Your hair dryer is 240v?
That explains it.Yeah Im in EU , everything is 240V , what do you mean ?
