Those cells are welded together in the factory. Sadly, that's not a process that can easily be done in the field so that entire 48v battery is out of commission. No harm in trying since that it is a goner.
I don't think drilling and tapping would work due to the softness of the material.Couldn't the bar just be cut in the middle and then either welded again or drilled for a bolt (to a new bar)?
With out regular "truing up" the SOC by comparing to Hydrometer this number is meaningless. Please get another hydrometer ASAP.Here is what the midnight is reading when I took those last pics. Looks like it's still charging on its own? SMA says 53% capacity....
That is correct. Carefully study the cable coming the inverter box. Be looking for something like this. One end is coming from the inverters the other two in each plugged into a battery. Unplug the offending battery but be aware that those contacts on each connector are still "hot".If I disconnect one of the whole batteries, I'm assuming I would still be at 48V? But my amp hours would be cut in half?
I'd want the system to be static - Not charging or discharging before I pulled that connector but they are rated to do that.I've now run the generator for well over an hour and then some without an issue. No smoking, no off gassing. Even if the midnight classic or the SMA is a reading true generator brought the overall charge up. Up from 53% when I started to now 64%.
I have found the cables that were mentioned with the Anderson connectors, just wondering before I isolate to only using a good battery, how I go about exactly changing the SMA?
Also is there anything I should do before I just yank the plug? Do I need to power down to go to master enslave SMA? Do I need to fully shut off the midnight classic? Should I yank the main cord that splits to the individual batteries and then reattach after disconnecting the bad one? Or can I just literally disconnect the bad one?
I would stop and get some voltage readings you have already had a battery blowSorry for the delay folks, been a couple crazy days between Christmas and today. I've been tearing apart everything looking for my dang hydrometer, can't find it to save my life.
I guess my biggest question at this moment comes from me midnight classic when it reads battery over voltage. Is it safe to continue using the generator to back up the batteries when the midnight classic controller is reading "battery over V"??????
