chasingentropy
Greetings all, i thought i would share my small off grid experiment. We have a large plot in the mountains with derelict buildings and raw woods. Rather than demolishing the buildings I figured I would use them!
I'm converting this old cabin to a mini solar power station. My priority for the project is to power my 37ft camper (or should i say glamper) and eventually power smaller cabins that Im building.
Camper has
1.8kw AC (summer only)
800w+500w+1500w total resistive heat load from three heaters. We do not burn propane for heat.
1.9kw water heater (20% duty cycle)
150w(50% duty cycle) peremiter and road lighting (must remain on at night for safety)
400w(intermittent loads) interior Lights, laptops, fans
180w(always on) media server/NVR, POE cameras, internet modem
360w(intermittent) 3d printer
So far I've finished 32 100w panels of various brands each connected to independent 40a mppt controllers which charge 10kw lipo4 bank and 2 kw sla bank (surge capacity) power bank. They power two 4kw inverters.
I also have a 2kw 4 stroke inverter generator and a 1kw 2 stroke generator for backup power. The generators feed 120->24v directly to the batteries. I'm working on a system to collect their exhaust heat to melt snow from the panels in the winter.
I plan to add multiple smaller substations scattered out over the property which all feed the prmary station.
Currently the equipment is in a box out front but once I've worked out all the kinks so it's less likely to catch fire i will put it inside the cabin.
Yes, those are power lines draped over edges of metal roofing. I am open to suggestions on how to gracefully route them into the house next to the front door.
Camper has
