SignatureSolarJames
Try Solar, the Grid will always take you back
the cheapest cell on the market is the 280ah, big announcement coming this week
The 280s have a volume discount though which makes them cheaper per/WhThe 18650batterystore LF304's ($149) are currently slightly cheaper than the LF280K's ($139) per wh. Maybe because they're a new product for them. And they are trying to draw attention to them. It got my attention. lol
If the pricing stays the same. They will be my next cell purchase.
Edit: just noticed that the cycle life is only 4k on the 304's. Versus 6k for the 280's. Probably due to cramming more into the same physical size.
Maybe I will stick with the 280's.
I'll stick with the 280's, just for the cycle life anyway.The 280s have a volume discount though which makes them cheaper per/Wh
Lol..I'll stick with the 280's, just for the cycle life anyway.
The 304's I have do maintain better balance than the 280K's I have (single stud from Amy at Luyan).The 18650batterystore LF304's ($149) are currently slightly cheaper than the LF280K's ($139) per wh. Maybe because they're a new product for them. And they are trying to draw attention to them. It got my attention. lol
Not according to 18650batterystore.Lol..
Lf304 and 280k have the exact same life cycle, it using same test method
I'll be sticking to my 304's ( except my little envision experiment)
No issues with balancing, here.The 304's I have do maintain better balance than the 280K's I have (single stud from Amy at Luyan).
Maybe you are thinking about the LF280N and LF280K that had different cycle life but they changed the parameters? Otherwise the spec sheet does show the 304's have lower cycle life then the 280K using same testing procedure.Lol..
Check the test c rating on the manufacturer's spec sheet..Not according to 18650batterystore.
Not so sure datasheet here https://cdn.shopify.com/s/files/1/0...duct_Specification_Version_B.pdf?v=1641489146Lol..
Lf304 and 280k have the exact same life cycle, it using same test method![]()
I must have missed it because both spec sheets have 0.5C.........Check the test c rating on the manufacturer's spec sheet..
280k's had double the cycles at half the c rate
Check the official eve sheet
For a fella that doesn't use cell compression, you're are concerned about cycle life?No issues with balancing, here.
But I'm not interested in the 2k less cycle life (according to 18650batterystore).
Linked in this post: https://diysolarforum.com/threads/e...nd-18kpv-aka-eg4-18kpv-12lv.61629/post-836914Check the official eve sheet
SureFor a fella that doesn't use cell compression, you're are concerned about cycle life?
18650batterystore only warranties according to their specs.Check the official eve sheet
Yeah.. funny how this new one show .5 c for both, while the earlier showed 4000 at 1c
Sure
Compression doesn't change anything for my setup.
I'm not concerned with the 304's I have. Never a heavy charge/discharge, very rare to discharge below 50%. One advantage of larger battery banks.Yeah.. funny how this new one show .5 c for both, while the earlier showed 4000 at 1c
This is after the 280k showed to be a total shitshow in capacity..
Yeah, I'll stick with my 304's..
Even at 4000 cycles, in my case it will be well over 17 years..
I think by that time sodium or other Chems will have the edge
These are designed for EV's. Solar storage doesn't push them anywhere near half the expected loads. My system doesn't even come close to 10% of it.
I'm dying here, that is one funny comment.
I know I'm not anywhere near 0.5C at any time either. I'm of the opinion the manufacturer specified the fixture in the spec sheet so I go by the spec sheet.
